heminut
Nice work! You're moving right along.
Boy, isn't that the truth! I'm 6"4" and at the time 235 lbs., and when I replaced the filler panel between the trunk lid and back glass on my Cuda I had to have my 5'8" best friend come over and do the spot welds in the trunk!You say you are a big buy, just wait until you have to crawl in the trunk to weld. I wish I had welding goggles to weld with as the welding helmet was a big pain.
@70chall440 Good idea, thanks for the feedback. I've been trying to figure out how to get that spot weld look with the plug welds.Awesome work, you might want to turn up the heat on your welder. From the pictures the weld beads are stacking/building up which is normally a sign that the weld is cold. Turn it up, start the weld in the center of the hole and relatively quickly make a little circle (takes some practice) and you will get what looks like a spot weld. When welding rusty metal (even surface rust) I like to start on the edge of the hole on new panel and pull the weld into the center and then make the circle. Doesn't always work but does more times than not.
