Hi guys,
Having some weird issues with a simple tune-up on my 72 Plymouth Barracuda / 318-A904 Auto Trans:
Friday
1. Changed Cap Has a weird black tab on top for some odd reason. Doesn't conflict with wire caps though. (Standard Company)
2. Changed Rotor Button (Standard Company)
3. Changed Coil/condenser (Standard Company)
4. Changed Voltage Regulator (Classic Industries) (Resin was completely drooling down and affixed to firewall).
5. Changed Spark Plug Wires (Standard Company 7 MM)
6. Changed Plugs (Autolite P/N 66 Copper)
7. Changed Electronic Ignition (Resin was completely melted away to bare circuitry board).
Problems in Process:
1. During coil change The negative wire was brittle and snapped at the base of the coupling where there was thick hard rubber end.
-- Fix: I cut and splice a new connector without the block and use heat shrink sleeve.
Saturday:
Finished plug installation along with boots spark plug boots.
1. Fired her up and noticed a vast improvement in idle and performance. Happy face time.
Sunday:
Tried to start her up...bit difficult. extremely rough idle.
Messed around with carb a bit...idle etc...
Started to smooth out a bit but was over 700 idle RPM.
Shut her down.
Monday:
Started her up and looked at timing...wasn't getting any kind of measureable reading...was bouncing all over timing marks...thinking it is the timing chain.
Today: No Start...No spark whatsoever...HELP Thing has a mind of it's own
SRKlegin
1972 Plymouth Barracuda
5.2L 318LA / Electronic Ignition
A904 Auto Transmission
Friday
Saturday:
Sunday:
Shut her down.
Monday:
SRKlegin
