Brake Rear Cylinder Questions
doubleyellow
Metro Detroit
Guys,
Rear cylinder questions:
- Is the cylinder the same part number for 10" and 11" rear brakes? Are the cylinder pushrods same or different length?
- Is there a gasket that goes on the cylinder to seal against the backing plate? I've seen some with and some without.
Thanks.
torsionbar
Check your FSM!
My recollection is that both 10" rear, and 11" rear use a 15/16" cylinder, and they are interchangeable.
Ok, I just checked my '71 FSM, 15/16" is correct for 10" and 11" REAR wheel cylinders.
And if you have rear lock-up issues, you need a smaller rear cylinder. I used one from a pick-up.
