70chall440
So, I have looked at all of your pictures and nothing I see in them would point to anything conclusive. Its possible that it was stolen somewhere a long the way, its just as likely (and more probable) that it was a derelict sitting in a field that didn't have a title that someone decided to make into a car (or flip) using a title and VIN from another car.
On the cowl, if someone welding up the numbers you should be able to feel them from underneath unless they cut them out and welded in a new piece of metal. Its just as possible that it was damaged and someone fixed it along the way.
I think you are getting way too deep into this (IMO). If you have a VIN and a title, I'd build the car and call it done. The pictures show a typical "old" dodge back in the day, essentially a parts car that someone scrounged parts for to try and put together or flip. I would not get wrapped around the axle about all this numbers crap UNLESS you bought the car because it was advertised as something specific (color combo, specific drive train, etc.) in which case you should have made the seller prove the claims in at least one way.
Put another way; if the seller said it was a 6 pack car, then there better be a V in the VIN to start with, then it should have torque boxes but other than that there is no way to tell. As to the color combo, unless you have at least a fender tag, anything is possible. You have to remember that these cars did not live an easy life and were hot rodded and beat to death, it is only when the values began to climb that anyone gave a crap.
In closing, you have what the title and VIN say you have, nothing more. As to it being a rebodied car or stolen, Id challenge someone to prove it numbers or not. That car needs ALOT of work but if you love it (Challengers) then its worth doing, but it is not going to be cheap or quick because it looks like it needs about everything.
Think it if as a "clean slate", you can make it into whatever you want.
What is the VIN number of the car?
