Will drop spindles that the salesman say is only for factory disc cars work on 11" front drums? I just put around, the drums work well. I dont want convert to disc.
I'm pretty sure all the dropped spindles out there use the bigger inner wheel bearing so the inner shaft is bigger in diameter. Your drums have a smaller inner wheel bearing and will not fit on the larger shaft.
No, if you're trying to bolt the drum backing plate to the disc spindle.
Drum and disc spindles are different, probably would have been a good idea to design a spindle that could be used for both, but that's not the case.
