Engine throws alternator belt
I have a 71 Dodge Challenger with a 340 engine (450hp/500tq) and when I go wide open throttle or rev the motor stationary, the alternator belt comes off. I have Powermaster single wire, 140 amp, GM style alternator. Fan belt alignment is good. I have a turn buckle style alternator bracket from March Pulleys. I 've noticed when I rev the engine, the alternator shows some flex. I am considering going back to the Chrysler style alternator and original mounting bracket.
Any thoughts?
pschlosser
Santa Rosa, California
My first thought would be make a video of the belt coming off, to see if I can identify where the cause originates. Particularly from the vantage point on the passenger side, looking down the long way of the fan belt with the camera aligned with the belt and all the pulleys. By watching it a few times, one may be able to figure out what's going on.
But going back to stock is a play I've used many, many times in the past. When I work on a Mopar, and something isn't right about it with aftermarket parts or a change from factory, if I can't figure it out, I'll find the stock parts and put those on or "put things back to factory", and in most cases, resolves my problem.
But then, I'm talking about electric fuel pumps, intake manifolds, carburetors, electrical systems, and other things changed by previous owners. We may sometimes give up power, performance, or some other function by removing aftermarket parts and returning to factory conditions, but it pays for itself with less heartache and frustration. In the end, I just want it to function correctly.
Bret Schneider
I have the exact same set up as you on a small block. No issues, works great. Make sure you have the spacers that come with the March pulley set installed correctly. Guessing maybe you are missing a spacer or have one in the wrong place. That would account for the movement in the alternator.
Thank you all for your comments/suggestions. I think I'm going to look into going to a Chrysler style alternator and bracket. Tuff Stuff makes a 130 amp alternator that is a single wire hookup (part # 9509RDPDP).
