E-B Mel
- Joined
- Mar 22, 2020
- Messages
- 8
- Reaction score
- 0
I need to find out the differences between three(3) '68-'70(late) 340 factory cast iron intake manifolds #s 2531915-2, 3462848, and 3462848 1. Thanks for the help.
The last 2 848 & 848-1 are the same , just a reference for how many times the mold was used .
All 3 will be the square bore for the AVS carb . 71 ws the first year for the spread bore intake & Thermoquad carbs .
These were great intakes & even the performance intakes like the LD340 only had a slight edge in performance although being much lighter being alum .
2531915-2...can i install any 4bbl 600cfm carb on it? will it bolt up to a 73' 340LA?I need to find out the differences between three(3) '68-'70(late) 340 factory cast iron intake manifolds #s 2531915-2, 3462848, and 3462848 1. Thanks for the help.
Application 1972 Plymouth Barracuda2531915-2...can i install any 4bbl 600cfm carb on it? will it bolt up to a 73' 340LA?
I went back to the stock cast iron. Because it was original to the motor.The last 2 848 & 848-1 are the same , just a reference for how many times the mold was used .
