Does anyone know what the gear ratio is for a 7 1/4 rearend for a 6 cylinder Barracuda. I replaced the slant with a 360. I eventually want to go to an 8 3/4 rear end. I was just curious what's in the rear end now. Is there a tag on the diff or something on the broadcast sheet that would tell me the gear ratio? I have the sheet but it's it pretty rough condition. Thanks
Your final-drive ultimately is determined by your tire size. My Signet came with 2.76 ratio and 13 inch tires. The f.d. worked out to be about 3.10 - - then I went to 14 inch ralleys and f.d. dropped to about 2.9 - - . I now have a 2.93 unit and with my 14 inch Toyos, ratio back up to the 3.1 range.
Remember that IF your tire diameter is 26.8 (or very close) your final drive ratio will be exactly what your ring and pinion are fixed at. (Could be explained another way I suppose - but some of you will get the 'gist' of it).
Much easier to measure the tire circumference and then divide this number by Pi - or approx. 3.14
Sure-grip units are available for the 7.25 but still not viable for anything larger than stock 318. As far as ratios, suggest nothing higher (numerically) than 3.23. I had stock '74 Cuda 360 over 40 years ago, with 3.55 rear and it revved over 5500 at only 105 mph. Not fun on today's highways.
