Gearbox removal HELP!!
Caramon311
Ft Bragg, NC
Could really use some help as I feel like I am missing something. I am trying to change out the gearbox on my '70 challenger, was originally a 318 but now has a 383 from a '68 charger.
I have disconnected the Pitman arm, and even jacked the engine up aboutan inch (maybe more). But I still cannot get the old gear box out of the car. I can find no combination of turning/twisting/tilting that will allow me to pull the gearbox out of the car.
Should I be taking it toward the front of the car? the back? through the top? the bottom?
Do I need to remove the engine mount from the passenger side and hoist the entire engine up????
Really lost at this point and could use some help, everyone I talked to before I started made the whole process sound pretty straight forward. . .
I am assuming that you have removed the 3 bolts holding the box in and have disconnected the steering shaft/coupler. It is tight and you may need to lift the engine slightly more. Not easy with the engine installed.
Yes, bolts removed and shaft disconnected. I'll see if I can raise the engine a little more but I think it was starting to lift the restof the car :BangHead:
