How fast should it go my 74' Cuda with a 440 run?
vracing
Carlisle, PA
I'm looking for some of you all's experienced opinions about my car. I have a stock wieght 74 barracuda with an aluminum radiator, 440-030 0ver SRP forged pistons, Ported and polished stealth heads, Lunati Voodoo solid roller 578-585 lift 273/279 duration @50, Edelbrock Performer RPM, Demon 850 DP, 727 with a 3000 stall converter, 3.55 gears, Doug Thorley headers, magnaflow x pipe with 3" exhaust. What do you think this car should run in the quarter? I haven't had it on the dyno so have no idea what the HP is at. If anyone has a similar combo and know what kind of HP they are making, feel free to speculate.
My future plans for the car are caltrac bars, caltrac split leafs and subframe connectors.
Adrian Worman
England
I expect low to mid 12's with that gearing and the carb and the ign timing and curve set right.
Got a set of slicks or on modern treads? Exhaust hooked up?
Trap speed will be well up in the 115moh range easy and if it is around that its a good indication of hp. Better gearing, uncorked exhaust, 28"x9" slicks should see late 11's easy.
Sounds like a good motor combo, the roller cam is your hp maker with those portted heads.
vracing
Carlisle, PA
Yeah, I've thought about the gearing too. I enjoy the street driving and going to car shows and don't like a bunch of RPM while cruising down the hwy. I'm not ready for some sort of overdrive set up. I was going to run some drag radials or et streets. This would be with the exhaust hooked up. I got a brother in law with a 93 cobra with a 331 and a Novi 1000. The car isn't set up suspension wise. He hasn't had it to the track or dyno yet. I refuse to look at the back of that car... I may put a 125 shot on my car. I'll be working the suspension and my combo over before the N20. I'm not sure what I dislike worst, Fords or my brother in law. I just sold my 80 Z28 that ran 10.90's on the motor/pump gas small block with Tremec TKO. I'm building a Willys to race and street drive. Until that's done, (could be a while) the Cuda is getting some attention! I've also thought about relocating the leaf springs to get some more meat under it.
Adrian Worman
England
I drive my 72 all steel Challenger to the track, bolt some 28" slicks on and run 13 dead at 108 best.
A little way off you're expectations but I do that with a 440 that's still got bone stock iron heads, intake, a 750 Eddy carb and 3.23 gears. Car is set up for autocourse and fast road use with stiff Hotchkiss suspension and that hurts off line traction loads, so does the 4 speed, exhaust stays hooked up too.
The horse power comes from a 510/507 Comp Cam and KB stepped dome pistons, just some very careful jetting, ign curve and some FBO ignition.
If I had your engine combo and found some 26" tall tyres I know that some practice would get me to very low 12's/late 11's, have fun with it mate :)
The 74s were insanely heavy , Mopar added a lot of weight in 74 . I have a 70 R/T SE that weighs 3550 & also owned a 74 340 4 spd that weighed 3850 even after removing the bumperettes & the steel bumper beams behind the bumpers
