Same problem with 70 Challenger R/T. It was a intermittent wire connection at the firewall bulkhead connect. The connection may look good, however, may be just loose enough to move around with heat/cold and vibration. I actually pull the male/female connectors out of the block, clean them up and reconnect with dielectric grease. If you have a new harness, that is when it really happens because the connections are so tight that they push out and you don't even know it. Steve
