Installing a trans in the old days by yourself; the way we old timers had to do it!
440WB
Michigan
I bench pressed the four speed back into my Cuda one afternoon after high school. Feeling all proud of myself, I told my dad about my progress when he got home from work. He looked at the work bench in the garage and pointed out the new throwout bearing still sitting there in the box. :mad:
several times in and out - forgetting and learning the term Frustration Lesson while getting thru the project with bloody finders covered in grease/dirt
440WB
Michigan
and about the time installing my New Clutch without scuffing the Glazed Pressure Plate. Could not figure out why my car would not go faster then 10 mph!
rklein71
Amarillo Texas
As a youngster, I put in a clutch disc backwards, oops.
pschlosser
Santa Rosa, California
I've replaced a few 727s, and the building block process works well to elevate the tranny. It is now my "goto" when a jack isn't an option.
But there was one time I wrestled one in laying on my back, after a friend helped me move the tranny onto my chest. It took every bit of my strength to get it in there. I recall this event, because I think it got me laid. A pretty young female bystander was so impressed by my tranny heroics, she asked me out, and we dated for a time.
dodgedream
bald knob,arkansas
I guess I was always looking for the hard way to do that. I would have the car on ramps in the gravel driveway and lift the tail shaft, 904 or 727 and slide a 2 x4 block under it. Then lift the front with the tail shaft as a lever and put one under the bellhousing. I would repeat until it was tall enough and then slide everything foreward til pins engaged and could get a bolt into it to hold it. Then take a deep breath and hope the converter hadn’t slid foreward. I usually used a wedge to prevent that so time to lift the tail shaft and install the crossmember using a scissor jack
340challconvert
Parsippany, NJ
At my age, the smartest thing I did as buy this Low Lift Trans jack from HF to my recent install of a 727A in the A66 Challenger. Car was on jack stands with floor jackets at the front and rear for safety. Was not going to try reliving my youthful strength and exuberance 😁
Paid $229 for the unit. Worth every dollar and "Worked like a charm!"
PITTSBURGH AUTOMOTIVE
800 lb. Low Lift Transmission Jack
I think we all agree transmission jacks are worth their weight in gold when you need one! Especially to all of us who have done it in a hard, muscle intense method! 😀
TripleBlk70
MA
OMG that brings back memories!!! I was 17 or 18 years old and blew the clutch out of my 70 challenger one friday night while attempting to race another challenger of all things. Somehow limped it back home and (since I live on a horse farm) pulled it into the machine shed to work on it. Put it up on jack stands and proceeded to remove the 4 speed by myself with no jack of any kind.
Getting it all back together was fun, but I figured it out and pretty sure I had to have some help lifting it back into place!
ceedog
va
In 1969 In my 64 Belvedere I had my 4 speed out at least 6-8 times. Same procedure each time, there was a small ditch in the back yard so the car straddled it, I would slide under car (very thin and tall 155 pounds) removed the trans, and other pieces, to lay it on my chest then roll over to get it out from under car. The only parts I didn’t replace was the case, tail housing and input shaft. A 23 spline so not to hard to get back in. Now I’d need 1 foot blocks under wheels for me to get even close.
