FJ5 1970 440
So this all started with run-on and wide open throttle issues. Didn't have a timing light to start with so I was retarding the timing in small increments and then running and driving the car. Results were going in a good direction. Got a timing light and found out it was at about 8* AFTER TDC. Doesn't make sense. So I tried 12* BEFORE TDC like most people seem to run and my cars problems multiplied. not only that but total advance was so high I couldn't even see the mark. So, is my distributor junk or has something slipped out of adjustment or what? The motor doesn't run hot, has 140 PSI compression, gas is good and plugs look good. Can I just keep on retarding the timing until I find the sweet spot?
