Misc E-Body/Mopar/race parts for sale
6PKRTSE
Misc Mopar Parts For sale:
1-new Dodge Ram lighted hitch cover $ 5.00
1-used Blown 426 Hemi blower cam $ 100.00
1-new 94-02 club cab body moulding $10.00
1- new P4120758 Mopar clutch fan for b.b. or Hemi $100.00
1-used Mopar Performance black wrinkle finish air cleaner for 4150 carb $ 50.00
2- new/used std Mopar performance windage trays $ 20.00 ea.
1-new 4.150 stroker Mopar Performace windage tray $30.00
4-used Bullit style 68 Dodge hubcaps $25.00 ea.
1-used E-Body power Steering gear box $100.00
2-used E-Body leaf springs & shock plates $ 100.00
1-used 8-3/4 742 2:96 center section $100.00
1-used Dana 60 3:54 center section & ring & pinion $ 150.00
1 used 4.0L Jeep auto trans yoke $ 40.00
1-used Mopar performance adj. pinion snubber $ 20.00
1-used E-body 727, 8-3/4 driveshaft $100.00
2-used steel crank dampers $ 40.00 ea.
1-used b.b. power steering pump $50.00
1-used 70 cast iron 4 bbl intake $ 40.00
1-used 70 B&E body oil pan $ 40.00
1-used 73-93 p.u. or Ramcharger b.b. trans cross member $40.00
1-used A Body 727 trans cross member $40.00
1-used B Body 727 trans cross member $40.00
1-used set 452 b.b iron heads $100.00
1-used 3.750 70 440 steel forged crank $150.00
1-new 4.150 Eagle stroker 8 bolt flange HEMI forged steel crank $500.00
2-used 70 Challanger front side marker lights $ 15.00 ea.
2-used b.b. motor mounts $20.00
1-used set od b.b. main cap & bolts $40.00
1-used tach drive distributor $50.00
1-new P3690936 cam offset bushing kit $20.00
2-new P4876926 HEMI spark plugs (4 plugs per pack) $15.00 ea.
1-new Hemi/b.b. many cam & plug dowel pin kits all mixed together $40.00
1-new P5249191 T-stat housing with gasket &t-stats $ 25.00
15-new P4006767 b.b. / Hemi lifters $5.00 ea. $60.00 for all
1-new PD-17 Durabond b.b cam bearing kit $ 20.00
8-new CB527HND Clevite std b.b. rod bearings $ 80.00 for all 8 pair
1-new MS1277HG Clevite std b.b. main bearing set $ 75.00
1-new P4529699 sfi approved b.b./hemi damper $250.00
1-used lot of misc cast iron exhaust manifolds, intakes, oil pans, alternators, starters etc.
1- Most brand new NOS in packages or slightly used (Dyno time only)
-5.7L Hemi fuel injection set ups(5)with throttle bodies, injectors, injector rails, spark plug wire assy's etc $250.00 ea. , Air cleaner box assy (6) $40.00 ea. , Flywheels (7) with hdwe $40.00 ea. , Bell housings (2) $100.00 ea., Complete engine bay wire harnesses (2) $100.00 ea. , idle pulley (5) 15.00 ea., tensioner pulley (5) $15.00 , Exhaust manifolds heat shields (6) $5.00 ea. Emissions tubes $5.00 ea. (2) many bags, boxes of NOS mounting hdwe, clips & fasteners etc.
Misc Race Parts for sale
- 1 ea- new Holley p/n 080770 770 Polished Vacuum secondary street avenger carb. $350.00
- 1 ea. New Holley p/n 083670 670 Polished Vacuum secondary street avenger carb $ 350.00
- 1 ea- new Holley polished replacement fuel bowl $ 15.00
- 5 ea- new Allstar p/n 86134 24” Gilmer style oil pump or drive belts $ 20.00 ea.
- 1 ea. used NX misc Nitrous dry fuel injection kit in a duffle bag with 10 lb bottle for the sleeper look. Can all be hidden. $ 250.00
- 1 ea. used 4150 flange NOS Super Power shot with jets , purge, fuel pressure shut off safety switch & blue 10 lb bottle $ 175.00
- 1 set new Speed Pro p/n R9771+5, 4” bore 1/16 1/16 3/16 ring set $40.00
- 1 ea new NOS Power Shot 4150 flange nitrous plate with gasket $ 50.00
- 1 ea new MSD p/n 8484 All HVC pro distributor rotor $ 10.00
- 1 se new Total Seal 4.310 bore 3.0MM scraper & expander set $ 45.00
- 4 ea new Wilson Manifolds Ford style Throttle position sensors $40.00 ea.
- 1 ea new 2” fan spacer $5.00
- 2 ea new light weight billet alum NASCAR style hood hinges $ 75.00
- 2 ea used 26” x 9.5” Hoosier cheater slicks $ 150.00 / pr.
- 3 ea used 31.5 x 13.25 Goodyear slicks $150.00 for all 3
- 2 ea used IHI RHB5 twin turbo set up $250.00 ea. Will separate.
Misc items for sale
- 2 ea new Jupiter pneumatic 1/8” NPT air pressure regulators & gages $ 40.00
- 1 ea new Drawtite hitch cover $ 2.00
- 1 ea used Cobra trapshooter radar detector, still works $20.00
- 1 ea new 12V cigarette lighter air compressor $ 15.00
- 1 ea like new 6.0 Horse Briggs & Stratton lawn mower, power washer engine $ $75.00
http://photobucket.com/6PKRTSE1 for photo's of the new items.
call 1-313-505-7948 Make an offer on all items. I have no use for any of the items & need to make room.
70challengerdane
washington state
actually come to think of it, do you know whether or not its a small or large yoke? i have the 2bbl 383 so its bigblock with small yoke setup. i have a driveshaft i can have shortened but so far im having trouble finding out how long the challenger shafts are...
6PKRTSE
I believe it is a small yoke. I'll have to go measure it for sure.
70challengerdane
washington state
haha i hope so lol i think my drive shaft needs to be shortened about 8 inches... so im not sure if im gonna do that lol.. do you know how much shipping would be to western washington?
spoolinhard
is the power steering gear quick ratio? is the pitman arm included?
6PKRTSE
I sold one already, but I may have another one left. I'll have to go check. The one I believe I have left is out of my A66 340 car & I think it still has the pitman arm. I don't believe is a quick ratio.
