1. Take off the front fenders, valance etc. and assess what you need; do you need inner fenders as well, how far were they pulled in? The driver's side inner fender is usually rotted out by the battery anyway, so I wouldn't put too much effort into saving it.
2. Get the replacement pieces first (core support and inner fenders). I like AMD.
3. Get 2 or 3 quality (American made) spot weld cutters, chinese are junk..
4. Take pictures of the way the pieces fit together.
5. Drill out the spot welds thru the top layer only, then separate the panels with a small chisel.
6. Mock up the replacement panels with clamps and drill 5/16 holes where you want the spot welds (plug welds) to be. Unless you have a quality spot welder. Disassemble and clean the areas to be Mig welded.
7. Reassemble the pieces, clamp them down and triple check any measurements you need to make, e.g squareness, core support is vertical, etc.
8. Plug weld up the holes to resemble spot welds (you can dress them with a 4 in grinder and flap disc after).
Now would be a good time to upgrade to a 26 in core support if you don't already have it.. Also the bottom of the core support is a separate piece that you may not need unless it was damaged or is for a smaller core support. There are only spot welds holding it all together. Im sure I have forgotten something but this is the general procedure and is not too hard of a job (compared to replacing a firewall).
Good luck!
