no turn signals
tgalisin
could use some help. 74 barracuda 318. turn signals are not working. replaced switch in column with aftermarket switch had extra wire plug not used. replaced turn signal flasher behind ashtray. still no turn signals. 4way flashers work any suggestions
The power comes through the flasher into the turn signal switch , start checking for power , if you have power into the TS switch & back out to the individual wires usually brown & green check for power at the lights you mayhave a ground problem at the light housings
