blubyou340
Does any body bknow how to tighten the steering box
Hey man thanks i will look im the book a nd do that the whole front i replaced probly not a bad idea for a pro alignThere’s a lock nut and screw on top of the box. Check the FSM for the adjustment procedure. I also needed to tighten the steering, but I found my problem to be the aftermarket steering coupler not fitting tight on the worm gear. I cleaned up my OEM coupler, installed new shoes and my problem went way. I have tight steering now. I might suggest that you investigate the entire steering system and determine where there might be any sloppiness. Might not be coming from the box, but elsewhere.
