Litchkar
Greetings Friends,
I have a dilemma; my passenger rear drum will lock up and actually keep the car from rolling. The first time I changed the wheel cylinder, thinking it would not retract correctly. It is still having issues, where there is smoke off the wheel. I checked the temp. and it was over 400 degrees, while the driver side was under 200 degrees. I took it apart, changed out the cracked shoes, disconnected the emergency cable and lubed it in case it was sticking. When I went to reassemble it, I had to crack the bleeder to get the wheel cylinder to retract to get the drum on. Took it out for a short run, and it is still getting hotter than the other rear. 10" rear drums, SSBC front disc with a Willwood 11/8" master and adjustable proportioning valve. Connected to a Hydraboost unit. This is a new issue, and I am at a loss to solve it. I think if it was the lines to the rear, then both sides would be an issue. Could it be a second bad cylinder, or crap in the line running across the axle. Thank you everyone.
