mjb765
- Joined
- Apr 6, 2010
- Messages
- 110
- Reaction score
- 25
I have a 70 Cuda with manual disc/drum setup. There is a distribution block under the master cylinder and what looks like an aftermarket proportioning valve with a knob mounted over the rear axle before the "T" block on the rear end. The rear brakes are staying engaged and dragging. They were locked today and the only way to free them was to open one of the rear bleeder valves on a wheel cylinder. That part under the master--is it just a block or do they go bad? I can post a pic of the block under the master if needed if the opinion is that it may not be factory either.
