Ariovistus
Hello, It has been awhile. A friend has a 70 Plymouth Barracuda with a 383 automatic. It has a mystery rear axle. He said it came with a 3.23 rear axle with a Limited slip, but someone swappped it for a one wheel wonder. He wants to restore it back to original. A friend says He should put a 2.93 gear ratio rear end so He can have a freeway friendly car, but yet have a good off the line response. Another friend says to put a gear vendor in it and have a 3.55 rear axle. It would give his car a 2.84 final gear ratio at 65 mph on the freeway. He has a a gear vendor system, but is reluctant to have it installed because He wants to keep it simple. And the Purists say to put the 3.23 rear axle in to keep it original. But the car will be turning 3000 rpm at 65 mph on the freeway. He does not want the engine to work too hard and have a limited top end speed. So what is the best option? I look forward to hearing from the Experts on this forum, because He is not sure what the best approach is. Thank You.
