Monty's 340
Update On Rotors, located a potential source sold by Jegs and Amazon, need to verify fitment. Company call R1 Concepts show a selection or rotor only from OE type to drilled and slotted performance type. Shout out if anyone has used them and found them to be a fit. Thanks all.Yes, I believe this is correct. The inner bearing is larger on the later ones and so you need the later spindle. This was the basis for the disc-o-tech article using Cordoba parts, or something. Spindle, caliper bracket, caliper, and 11.75 rotor. Too big for 14 wheels.
I found it:https://www.allpar.com/d3/history/mopar/brakes/disc-main.html
https://www.r1concepts.com/details/1972-dodge-challenger-blank-brake-rotors/497320https://www.r1concepts.com/details/1972-dodge-challenger-blank-brake-rotors/497320
Cheers
