Seat differences
Avalanche
Massachusetts
the frame is similar , installing 70 covers onto those seats & using the plastic backs works fine , you may have to buy or build foam to match the contours of the different covers
So if I use 71 frames, I can install 70 foams with 70 covers and backs. Is the button on the side of the seats to release the latch the same and will it work with the metal covers that are not in the 71 seats?
No. The button is different. On second thought, I want to look at a 70 and a 71 seat tomorrow to know for sure.
I think you will have to retain the 71 seat release , but everything else will work
Avalanche
Massachusetts
Sounds like I can still use 70 foams and covers but will need to use the 71 plastic back covers to work.
There is a good chance. It rained all day here and is supposed to do the same tomorrow. I can't untarp the parts carsuntil the rain stops. Then I can take a look at the seats.
Avalanche
Massachusetts
I went to look at 71 seats today and the backs looked exactly like my 70 backs with the metal sides, so I bought them. I read some where that they used these seats until 71 1/2 and then switched over to non metal side backs.
Thanks for help.
The only thing not present was a drivers side track, so if anyone has one let me know.
The difference may be on the side where the button goes in. It is still raining here in S. FL. It is supposed to do the same tomorrow and quit on Tues. If you don't know if the 70 parts will fit the 71 I'll look for you.
Avalanche
Massachusetts
The seats look exactly the same, so no need to go to all the trouble of uncovering the car.
Thanks for all your good advice.
Heykach
1970 cuda seat frame
Does anyone have a rear lower seat frame for sale?
Thanks!
SRKlegin
Roy, UT
Hard to find some newer style Mopar seats. I would like not to slide around. Seems like they could've added a higher cushion...I am always scooching up. Did brand new foam did the trick when you guys restored your interior
