jackn440
Thanks for the reminder moper, those things always slip my mind. As far as the fine tuning goes, I've gotten it dialed in, except I'm still experiencing a miss at low rpm that makes itself more noticeable as drive time increases. I rechecked all of my wiring for the electronic ignition, warrantied out my MSD coil for a new one, and still no change. The ballast resistor is building lots of heat, to the point where I can't touch it. Don't think this is normal, but I could be wrong. I have two theories: voltage, or vacuum. When the engine is idling in gear, the amp gauge reads slightly negative, and it is the lower rpm range when it gives me trouble. I drove it around on the interstate for 30 minutes tonight at a steady 75 mph and it didn't give me a bit of trouble until I pulled off the highway. My other idea is that maybe the new cam is not pulling as much vacuum and somehow screwing with the advance. My friends are trying to help out, but at the same time they are taking the opportunity to "suggest" that I should just sell the car to one of them....Not gonna happen though
