Hello again!
I've got another probably dumb question or two. I am running electronic ignition with mechanical and adjustable vacuum advance on a 440 and an Edelbrock 1411. I have my vacuum advance running from the carb's "timed vacuum" port to the distributor (rather than "manifold vacuum"). I had previously set my timing to about 15 at idle with the vacuum disconnected but hadn't read up much other than that. I've been having some pinging in certain rpm ranges (with 91-93 octane) and figured I'd give it another look. I noticed that at idle I was sitting at probably 35-40 degrees of advance with the vacuum connected which left me a bit confused. I was under the impression that the timed advance doesnt pull a vacuum until higher in the rev range? I can adjust the vacuum advance screw super far out and get it back to 15, but I imagine I'm basically just cutting off all vacuum advance at that point? Any insight would be super helpful! Also worth noting is that I have the performer rpm intake with the vacuum port plugged.
