Trunk Floor help
Cupracer
Denver
I am in the process of replacing my trunk floor, ext, and lower quarters. My question is all have been removed and my tail light panel is still in place, I am going to replace the tail panel also. Can/Should I do the trunk stuff first or all at once? If I remove the tail panel should I weld in a brace for support and so everything stays where it should be. First time doing this, using AMD, and everything has gone good so far but then taking stuff apart is the easy part!
Thanks in advance.
ramenth
Beaver Dams, NY
When you say lower quarters I take it you're talking about patches behind the tires?
Personally, I'd replace everything at once with the taillight panel out of the way. It'll make it easier to slide the new floor and the extenders in. The quarters will still be held in place along the drain edge and the wheel houses.
