tublar control arms
I have Magnum Force upper control arms and they work great. Much more caster and camber adjustments possible for better tire wear and handling. There are several companies out there making them. They are all better than stock and some are much stronger than others which is what you need if you want to drive your car hard and/or do competitive road course type driving.
Hotchkiss levels the upper control arm & give better handling but at the cost of loss of anti dive .
All tubular control arms will allow better alignment settings with increased caster & can improve handling .
1 thing to consider though is every tubular control arm is welded weakening the metal beside the weld so they can fail , the factory arms are stamped from 1 piece of steel & do not break & with the use of Moog offset bushings you can also increase the caster settings for a fraction of the cost of tubular control arms .
So it is your call .
