What brand of rear shocks is everyone using?
gran coupe john
Ohio
Tried advance auto, and rock auto. Where is the best place to get these shocks for 71 gran coupe
Often the rear stance is affected by the setting of the front T bar on the opposite corner , have you tried adjusting the right front ?
gran coupe john
Ohio
Those Monroe shocks are new. Never seen that before, but the car was completely tore down. Makes sense that I didn't get it back together right.
Just an FYI Shocks do not support weight.
They are designed to dampen the compression/ rebound cycle of the spring to keep the tire in contact with the ground.
Air shocks support weight and are never recommended, They were a band-aid back i the 60s and 70s.
If the rear is too low, replace the springs.
But as Chryco says the front end could need the ride height adjusted.
cuda joe
nj
you need to ask the aligement shop to do that it;s not done automatically .. raise the front to unload the suspension to adjust the torsion bars
gran coupe john
Ohio
He is aware of the torsion bars needing adjustments. Plus alignment.Getting done on Friday, weather permitting. Have to trailer it to the shop. Hoping this is the last time I have to get a trailer.
gran coupe john
Ohio
Back in 87 was the last alignment. Can't believe I found this document. Hope it is readable. I sure will give them the information you sent. Thanks !!!
gran coupe john
Ohio
Won't be going to get the car an alignment. Rain in the morning, had an 8am appointment. Back in January had it scheduled and it snowed. Go figure.
