Frame connectors....oh, the humanity!
Doc Corey
Raymore, MO
I am finally installing my frame connectors. If you don't hear from me by tomorrow, send a search party
Doc Corey
Raymore, MO
Hey, now, you guys are going to muddy the water, and I'll never be able to unload this axle.
Doc Corey
Raymore, MO
This US Car website shows some pictures of these connectors welded in but nothing clear to show how this is to be tapered down to fit the narrower car frame rail in the back.
71droptop
Lower Hudson Valley
Just saw this and thought I would chime in. I have a convert. If you ever saw it on a lift you would see the door to quarter gaps were outrageous.
Back on All 4's - it looks goods. Point being when I do install my Frame connectors - the car will be supported under the rear axel and at each lower control arm.
318/auto/ 8 3/4. Best of Luck.
70chall440
Western Washington
I have installed 4 or 5 sets of these and I don't know what you mean by "tapered down".
Pistolgrip496
This is how it turned out for me.
Ronbo73
Dudley, MA
Hello Pistolgrip496,
I have a set of these frame connectors and was wondering how you routed the emergency brake cables since the path for them will now be blocked due to the frame connectors themselves.
rklein71
Amarillo Texas
I cut holes in the sides of the connectors so they route thru them.
Pistolgrip496
I ran the cable through the connector
Old Mopar
Doc
having welded in frame connectors and more building a track car...i would remove the rear eand and springs, engine and k frame etc as currently that unibody is flexing from all the weight hanging off of it, rather than at rest.
Love
My car is faster than most
Doc Corey
Raymore, MO
I assure everyone that I lifted it on the rear axle and front tires. If it's going to flex, the 426 Hemi will probably be responsible...
Zell
@Doc Corey awesome build - what type of jack (if it's a 'jack') that's pushing up on the leaf spring in first post?
Also - what kind of paint/undercoating did you use on the bottom once you welded the frame rail connectors in?
70chall440
Western Washington
Typically I put sub frame connector in with the car on my lift, I have also done one on my Rotisserie, either way I have never had any issues due to the manner the car was supported during the installation.
