under body.
michael bucklew
this is the front wheel well --back side---if i recall there was a heavy coat of underbody or similar material on this area. i used truck bed liner in the rear wheel wells. and used siliconized rubber as an under body in other areas. the front fenders still have the factory coating inside---no wheel wells on car. came that way----left inner coating in place. there are two holes as seen, does any one know what goes here????
Those two holes are for the plastic pins that hold the firewall insulation pieces in place. There are several of those holes along the firewall.
michael bucklew
ok-- that explains all the extra holes----used dymamat up as far as i could place it.
