70 Cuda 440 Headers
WhiteGP
I'm looking at Headers for my 70 440 Cuda, 4 speed... I see a lot of positive remarks on TTI headers, As you all know the passenger side clearance on this car/motor combo is extremely tight. Does anyone have recommendations / comments. Spark Plug clearance etc ...
I'm looking at these headers with the ceramic coating https://www.ttiexhaust.com/TTi383440134.htm ALSO, I have seen some comments on the Dougs site that specifically says to NOT break in a new motor with the coated headers?
mrmopar340
Shawsville Virginia
Don't break a motor in with any new headers. The initial temps will cause them to discolor or ruin the ceramic on them. Found out the hard way.
Steve340
New Zealand
I you have the old manifolds/exhaust system you can use those to break the motor in. Post #3 is right from what I know.
I was told by boss of the coatings company to install the coated header, wipe clean with prepsol and then run the engine for a few minutes and switch it off and allow the coating to cool.
Drive gently for an hour or so to fully cure the coating.
I did what I was told and the coatings hold up pretty well.
It's still a little warm here in the desert, but I'm going to install big-block TTIs, Doug's and Hookers into my 71 Barracuda. I'm betting on the TTIs fitting the best! I bought the Hookers for breaking in my spare 413 and the Barracuda's 440 because ceramic coated headers don't like breaking in engines. Like Mrmopar340 and Steve340 said, you need to cure the ceramic coating.
WhiteGP
As always, good advice :cool:
MoparCarGuy
Any updates on your header fitment testing?
It finally cooled down here in the desert. Highs in the 60s and lows in the 20s! Seriously thinking about using my 70 Challenger instead of my 71 Barracuda. I can swamp in the Doug's headers pretty easily as they're for a 383/400. Then I can pull the original 383 out (it needs rebuilt after 250k + miles) and drop in the 413 my Son and I built, break it in with the Hooker headers, then swap in the TTI headers.
