Turn Signal Switch headaches...
Oystercopy
Hey guys.. so just today, I ended up trying to replace my switch in the column. I had bought one from RockAuto (I was ordering other stuff) and what came was a defective switch. The manufacturer is Standard Auto Products and the switch itself looked OK, but it had a significant defect. It was nearly impossible to move the cam (yellow plastic piece) left and right, which engages each turn signal switch. I could hardly move it with my hands until I manually released the little tang (screwdriver touching it in the picture). Once I attached the lever to it, there was NO WAY the lever was going to move it any better than my own fingers doing it. I noticed that each time I moved the cam left and right, the mounting screw would loosen a little bit, which made it impossible to trust it not coming loose in the column. So, I modified the little tangs to take some pressure/tension off the things and it worked for a while, but after about 10 times back and forth, one of the tangs ended up breaking off and I was back to square one. The metal washer/retaining ring also didn't fit properly, so I ended up having to shave some of the white frame to get it to fit also (see pics). So, now I'm looking at different manufacturers. But it seems like ALL of them come with a yellow cam now, so they might all be the same. Beware of trying to use this item, because it will end up damaging/wearing down your turn signal lever if left unchecked. Hope this helps someone!
Oystercopy
I thought about trying to do that, but in order to pry the cam off the old one and put it on the new one I think I'd do more damage to the plastic than it would help.. Plus you've got to transfer the wiring over as well of that cam.
CORRECTION: Not Standard Auto, but Skyward Auto Products.. see picture.
EW1BH27
Canada
Quote: "So, now I'm looking at different manufacturers."
If you didn't see it, member TWS has this for sale.
EV2RTSE
Well, count me as one. I'm rebuilding my column and the exterior parts of it just got done at the powdercoater. I also ordered that exact switch from Rock and only took a quick look at it, but noticed it seemed cheap. I have a couple of original 70 switches that look ok but I'm not thrilled about the idea of reusing a 54/55 year old electrical part that is so critical. Changing the cancel cam shouldn't be that bad but I'm not crazy about the appearance of the hazard switch either. I know you have to grind it down to match the shape of the 70 so it fits in the housing but it still looks way different. I've heard of drilling out the rivets that hold it together & using the original hazard switch and putting it back together with small nuts & screws. Fun fun fun.
EW1BH27
Canada
I have a 54/55 year old 1970 switch that I wanted to keep because the flasher button uniqueness and still works great. It was taken apart and thoroughly cleaned, burnished the brass contact rivets, slightly bent the cam's "wire" connections so they'd make good contact, shrink wrapped a couple frayed wires and greased moving parts.
Oystercopy
Thanks for all the replies. Yeah, I might have chosen to rip the thing apart and drill out the rivets and all that stuff, but I didn't want to cause more damage to the unit... But since i'm probably throwing it away, I guess it wouldn't matter🤣
I'm waiting on a new one to come that I've confirmed with the seller that the cam is easy to move. It'll be here in a few days and we'll go from there.
One of the sellers I contacted said that their part was made in the USA so if this one that's coming doesn't work, that's the way I'm going to go.
I know this sounds crazy, but for years I bought drill bits from China because they are so cheap. I would even resharpen them on my grinder. The recently I bought a nice made in the USA drill bits. Not only me, but my son, notice how much faster and longer they last! And I will only buy engine motor mounts from 440 Source as they always fit great!
Oystercopy
That's hilarious. I recently bought some USA made bits as well! And they drill through steel, where the cheaper, DeWalts don't hardly even drill through steel...how funny.
cudahook
Highland, CA
I'm tagging in a little late, but I just installed the same signal switch and it's defective, too. Switching it from the center position to either left or right felt way too tight at the get-go, and it felt like something was hanging up, as well. After installation, the signals blinked fine but stayed on solid with the switch in the center position. I requested a replacement and ordered a second one as backup. All seem to be the same units made in China and range from $15 to $70. I sure wish there was an alternative.
I replaced the firewall, wiper cowl, roof, driver’s floor, & trunk pan; this was a couple hundred spot welds. I bought a 3 pack of Chinese spot weld cutters from Amazon. They were supposedly ISO quality and made of M2 tool steel (tougher than High Speed Steel). They looked good, but each bit lasted about six spot welds and were toast. I bought a 3 pack of American made bits, also iso/M2 tool steel. They were twice the price and I was concerned that they looked exactly the same as the Chinese bits….. But with ONE bit I did the entire rest of the car! Chinese drill bits, and chainsaw blades for that matter, are a false economy; yes they are cheaper but the quality of the metal is crap.
Sorry for the rant.
Oystercopy
Reporting back.. the last one I ordered was from a seller called AM Auto parts on amazon. I'm pleased to say, the cam moved without too much effort. But I also chose to file out the bottom of the cam, so that the turn signal lever fit more snugly when the screw was tightened, and that seemed to help quite a bit.
Oystercopy, I tried to find the turn signal switch on Amazon sold by AM Auto parts, but failed to find it. I was hoping to post a link for others who might need one. Could you post a link? Thank! And glad you found something that works!
plymouth67
I used the Rockauto one the OP posted about in my 71 and it works just fine. Maybe OP just got a bad one.
Oystercopy
For some reason, amazon wouldn't let me copy the link to the actual webpage. But this is the same part made by the same manufacturer
The Manufacturer was TRQ
Hopefully this link works?
Oystercopy
