Mopar426power
Love that color!
Looking GoodFinished the front end today. The AMD bumpers fit great. I have the rubber inserts on order. Also there are NO blacked out headlight bezels out there so I painted these....used SEM trim paint. Same on the grill.
THanks much yes they are incorporarted into the fenders I bought....thank you very much!Did you find the headlight brackets you asked about in post #42? I was trying to guess at the bracket you asked about. Is it the one in the lower right side of my photo?
Terry W.
Thank you!I'm not familiar with that wiring package. As far as a pin out there is none. I made one for the turn signal switch. It looks like what you showed. There is a makeup plug they sent you? If there keyed(made the same) the same it more than likely it should work. Anyhow maybe this will help.View attachment 135191
Thanks Terry - at this point it's hand to hand combat with wiring! That sounds like a great June Saturday morning job LOLI was looking at your photos in post #44. You may want to black out the color portions you see behind the grille. You can see how mine is done in post #45. Something to think about. The car looks great.
Terry W.
THanks the colors on the aftermarket switch cable do not align with above. I sent a note to tech support at American Auto.....txI'm not familiar with that wiring package. As far as a pin out there is none. I made one for the turn signal switch. It looks like what you showed. Is there a makeup plug they sent you? If there keyed(made the same) the same it more than likely it should work. Anyhow maybe this will help.View attachment 135191
Thanks - when you go to Sheet 4 wiring connector D do you recall if the color codes matched your OEM colors? Aftermarket turnsignal switches differ in color. 1970-77 Plymouth Dodge Chrysler Mopar Turn Signal Switch 1978-85 Truck NEW | eBay
No after market switch with a pigtailI'm not familiar with the wiring package you have. What I show is the original wiring colors and location. Are you using the original turn signal wiring.
So you needed to cut the plug from the switch? This is what it should be on the new turn signal switch to the AAW wiring colors. That your showing me. A better picture of figure E would help.WHITE (At the pointed End) ---Stop lamps---AAW colors -------White
GREEN ---------------------------- Left front turn signal---AAW---- Light blue
MUSTARD/Blk Stripe ------------Right front turn signal------------Dark Blue
RED -------------------------------Emergency Flasher----------------Brown
BLUE ------------------------------Turn signal Flasher-----------------Purple
Lt Green --------------------------Left rear turn turn signal---------Yellow ? looks like reads yellow
Yellow -----------------------------Right rear turn signal-------------Dark Green
Green/White Stripe --------------Horn--------------------------------Black
