4spd and Automatic Driveshaft the same?
gzig5
Mequon, WI
I’m converting my 73 Cuda from an automatic to manual transmission. Going from a 727 to an A833. Will I have to do anything with the driveshaft to accommodate the four speed or is the same length used in both applications?
gzig5
Mequon, WI
Thank you. That chart didn't specifically cover my year/model (73 Cuda 340/727), unless I missed it, but it told me what I needed to know. If staying with the same engine, it is most likely that the original driveshaft should work with either transmission. I can compare the two when I get home, but that should be one less thing I need to worry about.
