Russ Furchner
Long story here.... Seemed like a simple job, but I did a lot of things at once and want to verify if I'm on the right track. I had a lifter that was making noise, I could not stand it, so I replaced the lifters and pushrods. The cam showed no strange wear and compression was 150psi+ per cylinder, so I decided to just do the lifters and pushrods, it's the original engine, so I made sure I got the overall length right. I also replaced the metering block on the center carb with a new part from Holley (suspect) and re-assembled the top-end. I set and re-checked the lifter pre-load, so I'm confident that I did that right. On initial start-up, the engine would not idle and backfired through the carb if you let the RPM's get too low. I went ahead and ran it for 20 minutes @ 2000 (ish) as has been suggested to break everything in. I suspected vacuum leaks, so I checked the carbs and they seemed to be fine. I then pulled it all back apart and it looked like the manifold gasket had not sealed properly, so I started again. Once again on re-start, same issue. On the accelerator pump, it will rev smoothly, but not hold RPM. So I adjusted the idle mixture richer, and it helped a little. I decided the the intake ports did not seal again, so back apart it came. I have ordered new (different) manifold gaskets and am going to eliminate the cork gaskets after testing the seal with masking tape and marker. Will use a bead of RTV as others have suggested in place of the cork. I did not remove the distributor and firing order checked/rechecked. No soot on the plugs, I'm pretty sure I'm dealing with a lean condition, probably vacuum leak, but I'm also suspicious of the new metering block. I'm going to use the old one unless I can convince myself that the new one is OK. Someone along the way deleted the vacuum advance on the car and I want to put it back to stock. I'm suspicious of the new metering block because in addition the the vacuum advance port, it has what appears to be metering rods behind the jets in the supply tubes. The plugs on the top of the metering block are marked with "50" and the old metering block has nothing like that. Many questions here, but I would appreciate the opinions of those with more experience than me.
