74chlngrTT5.9
Small wiring updates.
Made the connector plug extensions and after many iterations have a bracket plate that houses the positive "buss" bar and relays.
In it I also made an insulator block that allows me to utilize an inline fuse for the alternator charge wire (white piece up top in middle).
It mounts up front to the radiator relocation spacer bracket.
Delivery man brought me a present. It is only the condenser for now as I continue my mock up. But it is a start.
Finished the mounting bracket setup for the radiator and AC condenser and fans.
Primarily because the fans have wiring I will have to address.
Start of condenser mounting tabs
Lower brackets are just slots that will cradle the lip.
Top brackets bolt directly to the top lip.
Mounted assembly
Top view with condenser sandwiched between intercoolers and radiator. This is the first time I have had all items bolted in at the same time.
It is tight and requires a definite sequence for installation.
Back to more wiring now.
Mike.
Mounted assembly
Mike.
