Hi Folks,
New here and need some help, I just picked up a 73 Challenger Rallye last week that has sat for 20 years, had after-market work done in the early 2000's with a new engine. Power Brakes. All of the lights work with the exception of the brake lights. Reading your forums and looking at wiring diagrams I've found that the brake light switch is likely where my problem is.
From the wiring diagrams (for a 74, I have a 73 assuming there was no change, posted on this site, super helpful!) I've found that there should be a wiring coming from Fuse block 3# D3 18P (Purple/Pink Wire?) to the Stop Lamp Switch Pole 1#, On Pole 2# should have D4 18W (White Wire?) to the Hazard Flasher Switch.
What I have I've found is a single yellow wire heading up to the wheel column, presumably to the Hazard Flasher Switch assembly? (going to rip that apart next) From the pictures I'm attaching can anyone give me any advice on what they would recommend starting with troubleshooting here?
Thanks!
Thanks!
