FOUND Bumper bracket to frame bolts
Cud@
Minnesota
Anyone have 2 of the bolts that hold the front bumper brackets to the frame on a 71 Cuda (I'm not sure if 70 thru 74 are the same?).
I also need the 7/16 - 20 X 2 inch bolt (measured from under the head of the bolt to the end of the threads) that secures the ear on each side of the block to the automatic transmission bellhousing.
RR70
Rating - 33.3%
1   2   0
Just found for another guy 3 of the bracket bolts and he only took one so 2 still here. Both are pitted but quite usable. $10 shipped to Minn.
Cud@
Minnesota
Can you post a picture of the bolts so I can verify what you have is correct?
Cud@
Minnesota
I only need one of the transmission bolts because I have one.
I'll watch for your response.
Cud@
Minnesota
I see the bolts now, looks good! Do you have the bottom transmission bolt too (7/16 - 20 X 2 1/4?
