dash pad
michael bucklew
dash pad #3 is a no go. same problem as with the other 2.. this company was recommended by several members..BUT___ they said they will try a fix the problem-----New Pad??? will see.. what I need is a photo of the drivers side to show how the pad needs to be.. the trim piece is the factory oem that was removed from my "71 Challenger...please photos to 1950zardoz@gmail.com
michael bucklew
Looks like your lower trim piece is not up where it should be. Who did you get the pad from?
yes the trim piece is in the correct position. the piece under the a/c controls are screwed into the correct holes. it cannot go any higher them it cover the control buttons------at this time I will hold the companies name.
