MerlinsMopars
- Joined
- Dec 16, 2019
- Messages
- 296
- Reaction score
- 116
This is a question probably asked a thousand times but I don't see any threads on the site here so I have to ask weather I should pull the inner like requested by the manufacturer. The springs are shimmed within .010 of recommended install height. Cam/ lifters and springs are a PKG from lunati. #10200703.
The spring pressures are listed at 115 closed and 336 open. 402 is the spring rate. Cam is .494 intake .513 exhaust 110 cl and I have 1.5 roller rockers. I have seen while researching that the cam lift is spec'd using 1.5 rockers which doesn't make much sense to me but if the rockers are figured into the spec'd lift then it would be considered higher.
Anyway, my question is, do I pull the inner during break in or not? I have gotten so many yes and no answers that while I dread doing it, at least I followed the instructions but also have been told by 2 local machinists, not to waste my time as that is normally only done at higher pressures.
I am really close to firing this motor and using lunati's cam lube, and also have a highly resistant moly paste along with the drivin br30 break-in oil.
I am leaning towards firing it with both springs but then I want to pull the inners also.
I am hoping to hear from the pros on this site. I have read posts on the A body site and the threads are totally mixed as I will probably get here also.
In answering it myself, I also am mixed so that isn't helping but my final opinion is just fire it quickly and run it in at the specific rpms.
Then I want to pull them so I can't blame myself for not following the manufacturer instructions.
I have broken in quite a few cams in this lift range and never had a problem but none were lunati.
