Well I finally threw the towel in and went and took off the 2 throttle bodies and returned to the sanctity of 2 Eddy 1406 carbs. The straw that broke this camel's back was no start when hot. I went to gas station and filled my tank and went to start and cranked fine just no run. After a half hour called to have car flat bedded home. Next day car started fine, ran it for a while, back in the garage shut it down and tried to restart again and no go. The engine is a gen 2 Hemi and I have had this on the car for two years and this is the 1st time with the no start problem. Put the Eddy's back on and in this 95* weather we're having car started right up after a 10 minute wait.
I tried resetting the Fitech calibration to stock but no help. The idle was erratic at times and the return spring in the throttle was a bear to operate. The other thing was I didn't want to spend half a day on the phone with a tech rep. Fitech should give a little more info than a folder how to install it, maybe some trouble shooting hints.
