fusible link
Dave360
Port Hope Ontario
hello
Im new to older cars and was wondering how a fusible link works and also what happens if I remove it and replace with straight wire and is there a modern replacement chip fuse maybe
and most important what size does a 74 challenger 360 take
thank you Dave
They come in different wire diameters. Just need to match yours. Available on eBay from Mopar dealers for around $10. for OE. Just get a couple so you have a spare in the glove box.
challenger6pak
It burns out if there is a major short in the cars wiring. Using straight wire will give you a good chance of catching your car on fire. This will normally cause your ammeter to start melting. Find the short, fix it, put in a new fusible link, and carry and extra as been advised.
challenger6pak
You should use the same size fusible link that the car came with.
Correct The fusible link is a type of fuse. If your car blew a 10 amp fuse you wouldn't want to use a 20 amp fuse. The point of the fuse is to prevent damage to the wiring or electrical accessories.
challenger6pak
This is what your dash could look like without a fusible link. 036.jpg043.jpg
