Lower Control arm bushing
KennyCuda
I really need help with this I have the lower control arms out of my 70 Challenger and im having a hard time trying to get the bushing out of them. I pulled the rubber out and just the metal sleeve is in there. You can't press them out because of that ridge so how do I get them out. Do I have to cut them out ???
mrmopar340
Shawsville Virginia
Do you have a socket the same size you can use to try and push it through. You may also want to try some heat on it to see if expanding and contracting will loosen it up. Make sure to grease the new ones going in just in case you have to do it again.
Katfish
Palm Bay, FL
Plenty of YouTube videos, 3 options
- buy the speciality tool
- cut a slot down the side and chisel it out
- weld a washer on the end, and press out from back
Xcudame
Southeast Arizona
I used to take a die grinder and carefully cut a slot in the bushing and then beat them out with a BFH and chisel. Then I saw the tap method in Mopar Action. It's so much easier. I think I got the tap from Amazon for about $50.
KennyCuda
I got mine out with a air chisel thanks for all the help
Vinny
Bergen County, NJ
OR, my favorite, thread in a 1 3/8" tap part way and then use a press. Never hammer a tap. My friend and I use this method and love it. I found the tap on eBay years ago. I believe I paid about $20 for two.
KennyCuda
I heard about the tap also but didn't know where to get it
