Manual Swap in 70-71 E-Body
chally71e
Oregon
I was initially planning on swapping the front and rear IRS, and a NAG-1 into my 71 E-body. I've since decided to stay with original suspension, and put in a modern hemi and a manual transmission.
I've been looking at the Tremec t56's and it looks like a substantial amount of cutting of the torsion bar crossmember needs to take place. I was wondering what other models everyone is installing? Ideally requiring less cutting.
I am doing a T-56 swap (from an auto) into my 72 Cuda using the kit provided from SST. The one exception I am considering is adding an additional top cross member brace - such as this;
70-74 E & 71-74 Mopar B-body Crossmember/T56 Magnum
I want to create a solid crossmember trans mount similar to the factory style - I don't think you can have too much support in a unibody...
Thanks for that, I was un aware of that option. I like that for the same reason.
