Well with nothing to go on it is difficult ,
4 types of cams hyd or solid in flat tappet or roller .
Stay away from Comp they are a poor choice or Mopars .
I prefer the Lunati VooDoo series, they produce great results .
I have no clue if you are running a manual with or without Overdrive , 4 speed is much more forgiving , what gear ratio in the diff , tire size , mostly used for highway or city , what intake you pan to use , I like the 300-14 Holley Street Dom intake , it seriously kicks ass . Headers or manifolds make a big difference in the cam grind used , ported heads or aftermarket ? they usually will flow better with more lift . Will you race it , autocross or drag or ...
