New 512 build planning
rickseeman
Arkansas
This is an interesting 2 minute video from Melling showing the oil flow through various main bearing clearances. You can't believe how tight the 1970 FSM says to run the main and rod clearance on a 440. And the Mopar B/RB manual says max allowable before overhaul just happens to be the minimum people say for a new stroker build.
Spyder
Far N. California
In that video, which number/flow would be preferred? Is 4 flowing enough that you're going to lose pressure and cause problems?
rickseeman
Arkansas
Yes .004" will cause you to lose oil pressure because of your lack of volume. Use your old HV pump. A new stock 440 is really tight like .0015". But you don't have a new stock 440. Everybody that builds a stroker wants .0025" to .0035". This means there is going to be a lot more oil flowing through your engine. 440 Source sells a Hemi pan and a 3/8" pickup. I won't even start a conversation about going to a 1/2" Hemi pickup. Everybody fights me on that. Do you realize you are going to have nearly as much horsepower as a 1970 426 Hemi Pro Stocker? Every single one of those guys used a dual line Milodon oil system and a 10 qt pan.
