in 71 Mopar used an 800 cfm carb on the 340 , the 750 is perfect for a 383 . If you are going to replace the carb , not sure why I would use a 750 Proform as my first choice .
You need a cam with a 112-114* cl while using stock exhaust manifolds for best results . The 702 should work well .
With the compression you have the short block may be just fine , you might be good just doing cam & heads
