V12T
Here is a link to a video of my engine. 512 sixpack shaky idle
512 stroker, 10.3 compression, stealth heads, ultralight crank, sixpack, modest street/strip Comp hydraulic lifter cam, headers (unknown brand), standard Mopar electronic ignition. 727 trans.
Engine sounds like it is missing and shakes at idle. Starts OK with a few pumps. Pulled plugs – good colour. Fairly new coil, HT leads, ballast resistor and electronic box. Compression tested to around 190-200 for all cylinders. Running in the dark – no visible sparks. (shorting). Exhaust seems normal.
Checked header tube temps with infrared sensor. All getting hot so all cylinders firing.
Engine mounts seem good (jacked engine up, no separation)
Fuel delivery (pump) seems good.
Checked float levels on carbs. Tuned as per instructions. Cannot adjust front carb – seized adjusters – new base plate ordered. Idle (rough) around 800 – will not go lower. Throttle plates not binding. Thermostatic choke working normally.
Done a vacuum smoke test and can’t find any leaks. Vacuum a bit shaky around 16-17. Has brake booster.
Flex plate secure.
Timing around 16 degrees rising to around 36 when revved.
Engine runs perfectly at high revs on test run but sometimes stalls when stopping.
I think the problem lies with the sixpack, not ignition, but I am out of ideas. Anybody help?
Flex plate secure.
