Timing chain dots. Am I losing my mind?
Bobby Sixkiller
So I tear into a 440 today to swap the cam. I set it to TDC 0. Check the rotor is pointing half out. Turn it another rotation and put the rotor right at number one in the distributor. Take it all down except the distributor. Both dots are up. Shouldn’t the top dot be down. Dot to dot. This is a chain from I think 440 source. S-340 part number stamped on it. 3 bolt gear. I thought they were all dot to dot. Am I losing my mind or is this gear set just made different. I’ll order a new chain and sprockets if I need to. Just no way do I want to do this twice.
Dot to Dot is firing #6 , both at 12 oclock is firing cyl #1
Glad to help , you can line up the dots at 6 & 12 the cam will be in the same position relative to the crank , you just have to turn the crank 360 * to position the dist for #!
You are correct. The FSM clearly shows the 440 timing marks at 12 o'clock on the crank gear and 6 o'clock on the cam gear. Doesn't anyone have a Service manual ?? These are simple questions and a FSM should be mandatory to even work on your car. The downloads for them are free. Here is the site so you can have one for free.
MyMopar - Mopar Forums & Information - Service Manuals
Huskidrive
My 383
toolmanmike
Super Moderator
Staff member
Iowa
Easier to line them up dot to dot. Then rotate the engine one revolution (12 and 6) and drop the distributor in for #1.
