sdcbowler
- Joined
- Jun 4, 2015
- Messages
- 184
- Reaction score
- 43
Hey there, Members
I am having an issue with my instrument lamps (’70 Challenger, Standard Gauges). The light bar, Console gear selector, and Heater switch lights refuse to come one. As a FYI, Dome, Door, and map lights are working.
When I put direct power to the orange wire at the ignition connector, all the light come on, but I don’t think the current is flowing thru the dimmer switch as turning the dimmer does not affect the brightness. Also:
-If I apply power to the fuse block on either side of the instrument lights circuit Double Orange or Tan side, the lights come on.
What I know/determined:
-Dimmer switch gets power from Head Light switch (BK Wire)
-I get nothing from the Tan wire in the Dimmer switch connector
-With the key on, with the head light switch in any position; I get no power at the fuse block in
The instrument lamps circuit.
-The Dimmer switch appears to be properly grounded. The main switch bracket for all the switches has continuity to ground. I check two locations on the dimmer bracket and it appears to be grounded. I removed the dimmer knob and the shaft had continuity to ground (don’t know if that should or should not be)
***My question is, if not from the fuse block (Instr Lmps Circuit), where does the orange wire get its power from?........or am I way off.
In the attached wiring diagram I can see the orange wire seems to originate from the ignition switch connector of the dash harness but there is no corresponding wire in the mating connector (refer to photo).
Any advice would be greatly appreciated
