What feeds the LPS and instrument buss
Litchkar
Whittier, Ca
Where are you guys finding these awesome colored diagrams
Classic car wiring.com. Mine was color, laminated, double sided. 8x11”. I recommend the oversized unit, a lot of small lines. Best part is they are made for each model year and which dash style you have. Best tool I ever bought.
floyd
Before you go tearing into every thing. You could have a bad dimmer sw. Check for power on both sides of the fuse. Then remove light panel and clean where I show the rust. Apply dielectric grease. The screw on the light panel are the final ground.
@Challenger RTA - Can you post a pic of the area on the light panel you are referring to? I’m pretty sure I have a bad dimmer switch but want to make sure I have the best ground possible upon reassembly.
This is were I posted my issues. Take a look at the inside and outside of sockets. Also the light bar socket insert. Every screw on the light bar is a ground too.
Dash lights a Brighter possibility​
www.forebodiesonly.com/forum/threads/dash-lights-a-brighter-possibility.34086/
